UT bonus pack and extra levels problem
blackhawk
2,690
I downloaded the above and when I try to open them, they unzip but I then get a box that tells me no program to run them and to go to view, folder options and select one.
I don't have a clue what to do! Anyone?
Terp
Banned
Jun 16, 2000
215
Did you unzip them, or move them to the UT directory and make sure the extentions are the same?
I am about tod/l it now, so will let you know if I have any troubles...I did, however, d/l the zip on my old system a few weeks ago and all worked well.
blackhawk
2,690
I did unzip, but it just creates another icon and I can't open the files.
I didn't unzip to the UT directory though as I thought there would be an install or setup program.
I can't access the files so can't open them.
Stosh
2,149
You need to do a clean install of UT. Then install the bonus pack. Somehow it never was installed properly. If it's a umod file, it should automatically recognize the setup.
Dufusyte
659
To install the Bonus Pack, just double click the .umod file and it should begin installing. If you are having trouble, extract the ZIP file to a temporary folder such as C:\Temp, and then use Start | Run to run the following command:
C:\UnrealTournament\System\Setup.exe install C:\temp\UTBonusPack.umod
(taken from the Unreal Technology page http://unreal.epicgames.com/)
JFK XXIII
29
I reinstalled UT, and have the bonus and Inoxx packs saved to a cd. Trying to run them, I got the problem described above. Right now they are UMO files, I tried setting them to use UT, but that just launches UT. Any other ideas on this?
JFK XXIII
29
Thanks for that. I figured my problem- the pack somehow got renamed to bonuspack.umo instead of .umod. I'm guessing that my cd burning software won't allow filenames w/ that many letters. Anyway, once I renamed it back to .umod it launched w/ a doubleclick.
