Using Vista for Wireless Configuration
owensdj
I installed the same 802.11n wireless PCI card into some XP machines and one Vista machine. The card install gave me the choice to use the Windows Zero Configuration utility instead of the manufacturer's software, but I didn't get that choice installing it on Vista. How do I change the settings to allow Vista to manage the wireless configuration?
go to run, type services.msc. scroll down to Wireless Zero configuration utility and start it.
That should start it up so you can connect to network with it....but now im drawing a blank on how to make it the default service...
