- Mar 18, 2007
- 11,959
- 157
- 106
Can you do this on current lcd monitors as a work around if you don't have a lcd monitor that has dual monitor ports ?
Originally posted by: Fox5
You mean can you have something plugged into each input? Yes, most monitors will have a menu option to switch between the two inputs, though it may be possible to find a monitor that will always default to one with no option to switch.
Yes. Is it ok to switch from VGA to DVI when the lcd monitor is on ?
