While I totally agree with you, the irony of this statement amused me 🙂Originally posted by: spidey07
You have to be REAL careful about reading anything about networking from folks on the web. Misinformation abounds.
Originally posted by: Captain Howdy
I do it so my port forwarding does not get messed up when I switch my computers around. It was a pain to have to keep changing the IP addresses in the forwarding table. While not using true static addresses, just address reservation via MAC address, the principle is the same.
Originally posted by: gizbug
I've heard its better to have your computers that are on your home network setup with static ip address, opposed to having them be assigned one each time they are connected.
Question is why, and what is the best way to do this with a router and windows vista?
...jigga what?Originally posted by: eos
My WANs are setup as DHCP, but my gigabit LAN is setup with static because I am using a switch.
Exactly.....I have 2 machines that are always on (FTP/File Server & Game Server) and I ran into the occasional problem throwing off my Networked Drives and the like and general network connection issues from the public side. PortForwarding for each game port to PC#2, but leaving 21 & 3389 on the FTP Server...gooood.
On top of that I have an old NetGear print server setup on a HP LaserJet, that is added by IP to my other machines.
There is no advantage whatsoever.
In fact there is a detriment to using stacially assigned addresses - more time to muck things up and more time to unmuck things.
Fact of the matter is you will most always get the same IP address with DHCP anyway depending on how your dhcp server is set up. On a home network there isn't any reason to not have a 90 day lease time. You have to be REAL careful about reading anything about networking from folks on the web. Misinformation abounds.
Originally posted by: Smilin
The advantage: It overcomes the limitations of cheapo home cable/dsl routers.
The port forwarding capabilities of them is very limited and generally consists of "forward this port to the addy I specify." This then becomes a problem because they are also using limited DHCP functionality that doesn't allow reservations.
So you setup forwarding then months down the road your IP changes and some ****** breaks and you are left scratching your head because it's been so long since you set it up and it's worked flawlessly for so long you don't leap to the simple explanation. Not a biggie really but it takes you longer to figure it out and fix it than it takes to just static it in the first place. And yes it DOES happen. Not often but if you go on vacation or leave a device offline for a while things may shift. That's what the D in DHCP means.
I personally use a mix. I leave DHCP running for when I hook up the occasional ephemeral device but use static addresses on my main boxes and printer that remain on the network the whole time. I just pick a static addy in the same subnet but outside the dhcp scope.
It takes all of 20 seconds to set an IP by hand and I'm good for years until I rebuild a box. This isn't an enterprise network :roll:
