Using rooted Android Phone as a sound card?
Praxis1452
2,197
So despite the fact that my laptop has 2 speaker ports, I've managed to mess both of them up because my sennheiser hd 555's have this gigantic connector which extends really far out and really long cable that I've managed to trip myself over twice...
So... I'm wondering if there' some app on android or some workaround that would allow me to use my phone as a soundcard as the speaker port for that works just fine.
Google has not been so helpful. Thanks for any help.
hennessy1
1,901
I don't think the phone as the ability to do that I believe Bluetooth would be your best bet.
vshah
19,003
24
if you really want to accomplish this, you could set up a shoutcast server using winamp/the shoutcast plugin. then point your android phone to that mp3 stream. set the shoutcast plugin to use the system sound ouput/"audio mix" (different sound cards present this mix in different ways)
should technically work.
much better option is to just get one of these:
http://www.amazon.com/Syba-SD-CM-UAU...4239802&sr=8-2
