strep3241
We have a metal building that we sell pumpkins out of in the fall time. We are trying to make it where we can use accept credit cards in that building. The building is probably 150 to 200ft away from the house.
We have cable internet in the house with a router. I bought a wireless repeater last year and we are able to get internet inside the building although the signal isn't that strong in certain places.
So I figured we were good to be able to hook a credit card machine up to the repeater via an ethernet cable. But sometimes the transaction will go through and other times it will not. Where we have the repeater plugged in is in at the other end of the building on the porch. Where the credit card machine is setup, I can pick up the wireless internet signal full strength most of the time, sometimes it will drop a bar.
When standing right beside the repeater, I can pick up full strength. So since the credit card machine is hooked up to the repeater, why doesn't it work like it should?
Are we having so much trouble because it is a metal building? It has a metal roof, metal sides and even the ceiling on the inside is metal.
I do not want to run a ethernet line from the house to the building. If it comes to that, we may not mess with credit cards. I was thinking of getting a longer ethernet cable and moving the repeater towards the front of the porch, closer to the house and leave the credit card machine in the same place it is now. Will that be my simplest option to try? What else is there I can do without having to run a direct line from the house?
