using prepaid phone's SIM card in an unlocked phone?
quangdaika
158
So I was thinking of getting a cheap prepaid wireless phone. Sign up for prepaid wireless and then use the SIM on my LG Shine. Would this work? Would all the options like buying minutes work? thanks
gorcorps
aka Brandon
Jul 18, 2004
30,739
454
I'm 99.99999% sure that prepaid phones don't have sim cards. They're on the CDMA network like verizon and sprint, neither of which use sim cards either. So no that's not an option.
Dec 30, 2004
12,553
T-mobile does prepaid, that is what I use, yes there is a sim card, and yes you can use it on an unlocked phone. Usually the phone is locked to a certain provider. But a sim card works with any phone that will accept it.
