wwswimming
Banned
2 screenshots to try & explain -
screenshot 1 shows wire parameter assignment window.
http://www.geocities.com/wwswimming/comprehensio4n.JPG
X position is tied to "brows up", so X-axis translation of the Point Helper,
represented by the cube labelled "comprehension", slides the eyebrows
of the model, from normal, to up.
i tried to do this with the rotation of the Helper controlling the eyebrows.
that's probably more manageable, given the scale of the model. the
way it is now, i have to slide the Helper out of view to get an appreciable
amount of "eyebrows up" in the facial expression.
second screenshot shows the morpher modifier controlled by the Point
Helper. had to zoom back to show the Point Helper, which moved out
of the starting viewport.
http://www.geocities.com/wwswimming/comprehensio5n.JPG
is there a way to use rotation to control a morpher function via wire
parameters ?
