- Nov 22, 2008
- 15,299
- 740
- 126
I looked around a little bit on the internet and seems like there are some software that can be used on the PC, but what about the hardware?
Can I use any PCI(x) card? or are there some special adapter that can be used to transmit too? Are there any recommended one, maybe with stronger antennas or something?
Can I get a dual band adapter and then have a dual band router? Probably the router software needs to support that?
How does it actually work? I plug my PC to the modem and then the wireless adapter on the PC will transmit like a router?
Do these PC run windows and then a routing software or these routing software are OS in themselves?
I want a strong dual band router, now I can go out and spent anywhere between $150 - $250 or I can get a good adapter and then convert my old PentiumD PC into a router.
Does anyone have experience with DIY routers? are they as reliable stock routers in terms of speed and connecting not getting dropped?
