Using old wireless router as a switch/splitter
marmasatt
Not sure if I'm saying this right but I think you'll know what I mean. I want to use this old wifi router to split ethernet to several devices. Hoping it's an easy answer. I now have like 3 devices under the TV (including the TV) that have an ethernet port. Can I just use this old D-link 615 and take the ethernet cable into the ethernet(Wan?) port and then use the other 3 Lan ports into the 3 devices?
Do I have to do any configuration or is this pretty much plug and play? I'm reading some stuff indicating you can't use the wan port if I'm trying to do what I'm indicating.
Let me know.
Thanks.
change the ip on it to +1 of the other device.
i.e 192.168.0.1 on main router 192.168.0.2 on the router you want to use as a switch.
then turn off dhcp on the secondary router and plug an ethernet cable in to a lan port not the wan port from your first router.
then plug in whatever devices you want but never use the wan port.
