using my pc as a PVR.......no sound
r0guenj
77
<FONT face="verdana, arial, helvetica" size=2>anyone know why i don't have sound when i record from tv on my pc?
when i watch tv through my pc, i have sound but when i record a show or even 5 minutes to test the record function, i get perfect video quality but no sound.
my sig has my setup.... thanks for any help.</FONT>
rbV5
12,632
*Make sure you have line-in checked in the record properties of the volume control(speaker icon in the tray)
*Make sure the "line-in" input is not muted during capture.
* Do you have your AIW connected to your soundcard's line-in like This?
r0guenj
77
thanks for the reply!
i hooked it up like the diagram shows. i will check the settings when i get home, but i think it is not checked. i will find out when i get home from work though.
i am assuming the audio capture is separate from real time use for it not to work even with sound during normal tv use?
thanks for the help!
