- Aug 28, 2003
- 4,084
- 17
- 81
we have a smallish outdoor fountain - about 5' 5" tall - made out of stained concrete.
Over the course of the past couple of years, there has been a lot of hard water build up.
I was wondering if I should use a muratic acid solution to clean it?
I've sprayed muratic acid over the river rocks in our rock garden, then rinsed the rocks off to clean them and was thinking I could do something similar.
Maybe have a big tub and submerge the individual pieces in a water/acid solution.. what do you think? how much acid to water should I use?
There will be two pieces - the base and bowl which will not fit in a tub/5 gallon plastic container - so, I'll have to figure something else out for them.
