Using laptop w/ cell phone...how do i?
StrangeRanger
For the life of me I can not think of the name of the pcmcia card I would use to use my cell phone to use my dial up acct. Total brain fart. Can anyone w/ experience with this suggest any name brands or types of cards to use. Please help. Thanks,
j
**EDIT** sorry, search function finally worked. Thanks anyway or go ahead and post if you've had good or bad experience doing this.
i have never done this but i do know that it totally depends on what kind of phone you have. The right person to ask would be your provider whether it be sprint, at&t, etc. Some phones aren't equipped to be used as a modem. If your phone is then you have to order a proprietary cable from the phone manufacturer. I also know that there is software out there that helps with the setup and transfer as well.
Hope this helps.
Cheers
