I've tried using my Extended USB Module supplied with my Abit KT7A on my ECS K7S5A.
In order to get it to plug in I had to "knock out" a small plug in the connector but as USB devices are not detected by using the module I must assume that the wiring configuration is different to the Abit motherboard?
Have any of you out there used a Extended USB Module from a different motherboard and got it working successfully without modification?
Failing the option of modifying the Extended USB Module where do you get the correct version for the K7S5A and what is the likely cost?
