I'm trying to use this script. My server has PHP 5 and GD is enabled, but the script isn't working...
I removed spaces from all instances of "< ?" and " ?>". Is there something else I need to do?
Code:
<?php
if ($_POST['tempBox'] != '')
// width and height of graph. These could also be user defined values.
$GLOBALS['width'] = 500;
$GLOBALS['height'] = 500;
// drawGrid draws X and Y axis with markers every 50 points
// We pass in the image resource to draw to
function drawGrid($passGraphic)
// Grid is grey
$gridColor = imagecolorallocate($passGraphic, 200, 200, 200);
// Draw two lines, one vertical in the middle of the grid (width/2)
// and another horizontal in the middle of the grid (height/2)
imageline($passGraphic, $GLOBALS['width']/2, 0, $GLOBALS['width']/2, $GLOBALS['height'], $gridColor);
imageline($passGraphic, 0, $GLOBALS['height']/2, $GLOBALS['width'], $GLOBALS['height']/2, $gridColor);
// Draw a marker ever 50 points on the X axis. We do this by starting at the center
// of the board, then incrementing 50 with every iteration. We also
// draw a mark in the mirror location to cover the negative side of the axis
for ($lcv = 0 ; $lcv <$GLOBALS['width'] / 2 ; $lcv += 50)
// Set tempX and tempY to the current marker location
$tempX = $lcv;
$tempY = 0;
// Convert to image coordinates
cartToPixels($tempX, $tempY);
// Draw the line
imageline($passGraphic, $tempX, $tempY - 10, $tempX, $tempY + 10, $gridColor);
// Now do the same for the negative side of the axis
$tempX = $lcv * -1;
$tempY = 0;
// We use the same method for drawing markers on the Y axis.
for ($lcv = 0 ; $lcv <$GLOBALS['height'] / 2 ; $lcv += 50)
$tempX = 0;
$tempY = $lcv;
imageline($passGraphic, $tempX - 10, $tempY, $tempX + 10, $tempY, $gridColor);
$tempX = 0;
$tempY = $lcv * -1;
// cartToPixels converts Cartesian coordinates to image coordinates. In our program
// they are 1 to 1, though you could easily put a coefficient in to scale it up/down.
// The two gotchas are, coordinates start from the center, and the Y axis goes in the
// opposite direction (image coordinates, increase in Y goes down. Cartesian, increase
// in Y goes up).
function cartToPixels(&$passX, &$passY)
// Start from the middle, otherwise 1 to 1 for X
$passX = $GLOBALS['width'] / 2 + $passX;
// Start from the middle, also subtract to flip for Y
$passY = $GLOBALS['height'] / 2 - $passY;
// pixelsToCart converts from image coordinates to
// Cartesian coordinates. Uses the same process as
// above but reversed.
function pixelsToCart(&$passX, &$passY)
$passX = $passX - $GLOBALS['width'] / 2;
$passY = $passY + $GLOBALS['height'] / 2;
// The plot function simply takes Cartesian coordinates and
// plots a dot on the screen
function plot($passGraphic, $passCartX, $passCartY)
// We use green for our graphs
$plotColor = imagecolorallocate($passGraphic, 0, 255, 0);
// Convert Cartesian coordinates to image coordinates
cartToPixels($passCartX, $passCartY);
// Then draw a dot there
imagesetpixel($passGraphic, $passCartX, $passCartY, $plotColor);
// Push out an image/png mime type to the browser so it knows
// a PNG image is coming and not HTML
header ("Content-type: image/png");
// Create a new image resource with the dimensions dictated
// by our width and height globals. Starts off with a black
// background automatically.
$im = @imagecreatetruecolor($GLOBALS['width'], $GLOBALS['height'])
or die("Cannot Initialize new GD image stream");
// Draw the grid on our graph first (under everything)
drawGrid($im);
// We start a loop from 0 (First pixel in width of graph) to the width end,
// converting image X coordinate to Cartesian X coordinate, then retrieving
// the corresponding Y Cartesian coordinate (remember, our equations are
// in 'y =' form. We multiply it by 50 to give a better resolution - e.g. multiple dots on
// the Y axis for each X. This gives us a solid line instead of a bunch of dots for steep
// functions. The higher the number, the smoother the line (and the slower the program)
for ($lcv = 0 ; $lcv <$GLOBALS['width'] * 50 ; $lcv++)
// Get the left most point on the graph in Cartesian coordinates
$tempX = 0;
$tempY = 0;
pixelsToCart($tempX, $tempY);
// Now get the current Cartesian X coordinate by adding our current loop
// value divided by 50
$tempX += $lcv/50;
// Here's where the magic happens. In a nutshell, we're setting the Y coordinate
// ($tempY) in relation to the current X coordinate ($tempX)
// by using the expression specified by the user. We use PHP's eval function,
// which allows us to take a string (the user's input box) and run it as if it
// were PHP code. We're also converting X to $tempX because that's the actual
// name of our X variable in our code, not just
// 'X' - but we don't want the user to have to type '$tempX', so we make it easy for
// them. This is the line of code to be especially careful of, as a user could insert
// malicious PHP code and do bad things.
@eval("\$tempY = " . str_replace('X', '$tempX', $_POST['tempBox']) . ";");
// Now that we have both coordinates, we plot it!
plot($im, $tempX, $tempY);
// We write the equation on the graph in red
$textColor = imagecolorallocate($im, 255, 0, 0);
// Now write the equation on the graph
imagestring($im, 4, 10, $GLOBALS['height'] - 25, 'y = ' . $_POST['tempBox'], $textColor);
// Output a PNG file now that it's all built
imagepng($im);
// Free up the resource
imagedestroy($im);
else
<html>
<body>
<div style="margin-bottom:20px; font-weight:bold; font-size:16px">Simple Grapher</div>
<form id="graphForm" action="?<?php echo rand(); ?>" method="post">
Enter expression: y =
<input type="input" id="tempBox" name="tempBox">
<input type="submit" value="Graph!">
</form>
<div style="margin-bottom:15px">Enter expression using variable X (PHP code accepted). Both axes in range of -250 to 250.</div>
<div>Examples:
<ul>
<li><a href="javascript:populate('cos(X / 30) * 50')">cos(X / 30) * 50</a></li>
<li><a href="javascript:populate('pow(X / 30, 3) - X')">pow(X / 30, 3) - X</a></li>
<li><a href="javascript:populate('pow(X, 2) / 15 - 200')">pow(X, 2) / 15 - 200</a></li>
<li><a href="javascript:populate('2000 / X')">2000 / X</a></li>
<li><a href="javascript:populate('tan(X/ 25) * 20')">tan(X/ 25) * 20</a></li>
<li><a href="javascript:populate('-3 * X + 50')">-3 * X + 50</a></li>
<li><a href="javascript:populate('rand() % X')">rand() % X</a></li>
<li><a href="javascript:populate('pow(X,2) % X - X')">pow(X,2) % X - X</a></li>
<li><a href="javascript:populate('pow(X,2) % X - cos(X/20) * 40')">pow(X,2) % X - cos(X/20) * 40 (favorite)</a></li>
</ul></div>
</body>
</html>
<script type="text/javascript">
function populate(passExpression)
document.getElementById('tempBox').value = passExpression;
document.getElementById('graphForm').submit();
</script>
<?php
