Originally posted by: Peter
Yes, this is normal on recent mainboards. If your front case connectors do that properly (very few do), some mainboards loop the signal back into the rear plugs when the front ones aren't in use.
This "poor" implementation is exactly the loopback capable design I was speaking of; the jumpers are closing the circuit to the rear jacks when no front jacks are connected at all. This requires BETTER front jacks that loop the signal back through the "return" wire when the jack is unused.
Bottom line: Stop complaining about the mainboard - this is the best approach there is. It's your case front connectors where an important feature is missing.
