Using EP-8KHA+'s USB Ports! Help! I can't use my mouse!
JustinSampson
Hey,
I'm trying to get the USB ports on my EpoX 8KHA+ to work but I'm not having any luck! In the manual it show a picture of the software to install the drivers but mine is different and doesn't have the "USB Driver" link. So how do I get these working? I can't get my mouse working since it's USB, help! 🙂
I'm Using Windows XP Pro BTW.
Thanks,
Justin Sampson
Make sure you enable USB ports in the bios. You actually shouldnt need to install the drivers for the mouse, but I did anyway.
Start with the bios if you haven't yet.
Also if you installed the spare USB bracket and have the mouse connected to this make sure you have the connector lead plugged in the right way round on the motherboard end.Your USB mouse should work straight from when you switch it on if USB is enabled in Bios ,mine did on the Epox 8KHA+.
