using ductwork to expell heat from cpu
gooblegook
24
ive heard of it being done(actually seen a picture), does it really work and how would one do that??
cwallace
Zim Hosein
Super Moderator | Elite Member
65,310
403
gooblegook do you care about appearence? If you don't hit your local auto parts store and use air intake tubing, not pretty, but will get the job done :)
ChrisADuffy
1,324
It really works but I have also read that if you have really good flow thru your case you should not hav to worry about this. My case has 120mm intake in front and one 120mm exaust in the back(cut with dremel), I am using the Enermax clear fansEnermax clear fans , can be seen in my pics below.
SteelCityFan
782
Does Dell still use an Air Duct type system? I don't even think they put a fan on the CPU heatsink using this method... at least back in the P2 450 days.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
Big OEM's, particularly Dell, do it all the time. It helps keep down noise and costs when you're building thousands, the engineering effort is well worth the trouble for them. Clothes dryer vent hose is a commonly used material for DIY's. I think it's particularly useful with Alpha HSF's, the sink fan can discharge outside the case, doing double duty.
Daovonnaex
1,952
<< Does Dell still use an Air Duct type system? I don't even think they put a fan on the CPU heatsink using this method... at least back in the P2 450 days. >>
I know that the Dell Precision workstation has one (one of my friends somehow acquired one free of charge), but I can't speak to their other computers. It's a Pentium 4/1800A, and the duct seems there primarily to make it cheaper, as the heatsink is PASSIVE and is smaller than the one Intel ships with its boxed processors.
trikster2
Banned
Oct 28, 2000
1,907
My P3 866 based optiplex at work: After using it for over a year I finally opened it up just to check it out.
No intake fan and a single 80mm fan on the back ducted with a nifty duct made for the case to guide the heat flow off the fanless heatsink/cpu.
The fanless heatsink is kinda strange, it's huge for a P3; a flat piece if alunimun with these flimsy loops of alunimum over the CPU. Very light weight and flimsy.
The fan exhausts; there is no intake or other fans.
All in all a very nice and quiet design.
