Using dd-wrt router as a signal booster?
wctkdman
Hi, I was wondering if I could use my dd-wrt'ed router to boost a wifi signal that is near my home. I live in an apartment that is really close to my school campus and it's wifi internet. I was wondering if I could use my router to boost and receive the signal so that I could use the campus internet on my laptop at home. My laptop antenna sucks and hi speed internet is really really expensive where I'm at, so would this work?
ForumMaster
7,792
i know that some routers can be used (with the appropiate firmware hack) to extend a wi-fi network's signal. there are plenty of devices on the market that do this and you can also consider getting a mimo card for the laptop.
Cloud Strife
Banned
Aug 12, 2006
475
You need to set up WDS under the wireless configuration tab. WDS doesn't always work for me, so I just set up the router as a client and use a wired connection to my laptop/desktop.
Madwand1
3,309
You could try using your DD-WRT'd router as a wireless client using its "client bridge" mode, and then connect using a LAN cable to your laptop.
The WRT54g can take add-on antennae, and also boost its own output, although that might be overkill. It's a two-way problem -- better positioning, antennae, and radio smarts are the best solutions; amplification of weak incoming signals is not all that viable; amplification can be used for the output side, but even then better antennae, etc., would generally be preferable.
You could also try the parabolic antennae tricks -- even with your existing NIC.
http://www.freeantennas.com/projects/template/
Note however that wireless is an ever-changing problem. You could solve it once only to be blown away by a neighbour doing the same thing with an over-powered WRT, etc..
