I had always thought that for the best stable OC you had to use the boards bios. I have an A8V Deluxe that is not a great overclocker and usually run below HTT 245 or it's not too stable. Playing around with clockgen has gotten me much better, stable results at lower operating temps than bios tweaking ever did. Is there a good reason for this? I'm running at HTT 290 now with pretty good results this far, if I had set it this high in the bios I would be clearing my CMOS right now.
In bois I have the HT set at 3X, HTT at 200, agp/pci lock at 66.6/33.3, core voltage at 1.5. I use clockgen to change HTT, Multiplier, and voltage if necessary. I just can figure out why my temps are so much better now, even with higher voltage.
Has anyone else had great results like this? I've ran benches to verify atcual clock increases and everything matches up. Tell me what you all think.
