Shielded UTP (UTP = UNSHIELDED twisted pair)...
Shielded or not, "outdoor rated" or not, it's a very bad idea.
The problem is not performance within the LAN, it's the possibility of dangerous power being imparted to the (shielded, unshielded, indoor, outdoor, white, pink, purple, blue, or plenum) cabling. Aside from the (likely) fact that it's WAY out of municipal, state, and national electrical code and EIA/TIA specification, and the fact that UTP will rot in the elements (even plenum rated), NO EXTERNAL COPPER SHOULD ENTER YOUR BUILDING WITHOUT ENTRANCE PROTECTION.
It's very dangerous.
In the (unlikely) event that it is your ONLY (absolute LAST) option. Then it should be in the largest practical metal (grounded to code) conduit, and entrance protection should be in place at both ends.
And, OK, you're willing to risk life & limb (so are the folks that walk in front of / get hit by commuter trains), there's a better than even chance that you'll fry all of your equipment ...then you (or your estate, the survivors) have to do it all over again. OH, OH, OH, AND, BTW, any incidental damage to you, your family, your friends, your house, or your equipment WILL NOT be covered by insurance, because you elected to install out-of-code cabling.
It's very, very, dangeous.
These and other details are covered in several discussions in the Networking Forum, search and read.....
FWIW
Scott
