Hi everyone!
I'm going to instal my IP cameras system, most of them will be outdoor.
From the beginning my project didn't include fiber.
PoE cameras, 8 different locations; in future will be a total of 16 PoE cameras; next 8 indoor
For network I already have:
1. Managed Poe Switch Zyxel 1910-24hp
2. 8 IP PoE cameras Hikvision DS-2CD2032-I
3. Surge POE protectors for each camera line one at the IP camera side and one at the Switch side
4. FTP Cat5e Otdoor ethernet cable
My big concern is about outdoor LAN network construction to limit lighting damages!
Few questions:
1. Outdoor ethernet lines underground or overhead(I can do it both ways); Witch is the best option for surge protectors to work right? I am confused which option will work best!
2. Outdoor grade, grounded FTP in plastic conduit/duct or in an grounded metal conduit/duct?
3. Generally if in an grounded metal conduit/duct an outdoor grade UTP will work?
4. Also for multiple LAN lines in the same conduit/duct plastic or grounded metal, FTP is better do not interference with each one?
Underground: Instead of grounded RGS (Rigid Galv Steel), grounded copper water pipes will do some protection operating as an inductor to lightning surges? Copper pipes are thin 0.7mm-1mm. If ok, Copper pipes will be good for direct bury or need a kind of bitumen/asphalt coat?
If I go overhead I can use grounded galvanized flexible spring tube (like spring shower flexible conduit), but again it's thin
Outdoor lines are max 30m(in which, underground or overhead max20m)
Any suggestion and experience will be great!
Hi. Since you posted in a 12 year old thread, I've separated your post and created a new thread in our Networking forum.
-Thanks
ViRGE
Few questions:
-Thanks
ViRGE
