I have a computer with novell, loading a batch file at startup that uses novell's file capture.exe with some switches. Now I want to use this same batch file and the capture.exe file on a computer without novell, but it tells me that PRINT.VLM isn't loaded...
I'm wondering if I can use capture.exe without Novell, if not, do you know any program that would do the same thing as capture?
I need something that would resize automatically the caracter size when you print in DOS. That way a 1000 pages report only takes 500 pages 😉
