So I just bought the Soyo KT600 Motherboard kit from tigerdirect and after putting in everything, I booted it and tried to install windows. But, while the installation for windows was going on, the computer suddenly shut off and started beeping. I'm pretty sure this is because of the built in processor over heat check that turns off if the processor overheats.
There are two things, first, the thermal paste on top of my processor has worn off a little bit, so the heat sink is pretty much touching the processor directly. Could this have heated it up too much?
second, I went to the Soyo website to see if I could find what was wrong, and turns out they say the minimum processor to use with this motherboard is the Athlon XP 1800. Should it really matter if I was using the Athlon xp 1700? Would buying a new processor fix this?
I don't know what else could be wrong other than that. What do you guys think? I appreciate your help.
