A while ago I bought a Radeon from someone in the U.S. I later bought one for my friend, also. When I hook up the card to my television, output is fine: everything is displayed in full colour, and the 60Hz refresh rate is no problem for my relatively new television. (In Europe, we use PAL and run at 50Hz.) However, my friend has an older television, and all he gets is a black and white screen. Can I change the ViVo module so that it outputs in PAL format, or is there a setting I can use to change the video signal from NTSC to PAL? (I tried to find one, but I couldn't locate it.) Or is there a jumper that changes the mode from NTSC to PAL? Or is the ViVo module on North American Radeon cards different from the ones sold in Europe, and will it therefore only work on European televisions that can handle the NTSC signal?
