This might be a silly question, but I figgur I should ask before I start cutting things up.
Anyways, I'm using this Ikea lamp, but with a 200watt bulb. The plastic switch that the lamp came with eventually melted from the inside out. I'm guessing it's because of the excess current that was pulled by the bulb.
In the mean time I've hacked off an identical switch from the other "reading light" section of the lamp to use. But, the switch is starting up to heat up, and I'm thinking that I should install a relay in this mothertrucker, just so that my house doesn't catch on fire one day.
I've used a few auto relays in the past, and those were DC. Would it make any bit of difference if I used those same relays (the ones that I've used on my car), on this lamp? I'm guessing a 40amp relay should suffice, but I don't know if there is a difference between AC and DC relays.
And if I choose to just use a huge 30amp switch, is there such a thing as an AC or a DC only switch?
