Using Airport Express and Ethernet Connection
ChAoTiCpInOy
6,442
Is there anyway to use both connections simulateously so I can surf on one and then watch streaming video on another?
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Not sure I understand the question?
ChAoTiCpInOy
6,442
I have a Macbook Pro that has a wired and wireless connection. I can connect to two different networks with the two connections. Is there anyway I can use both connections at the same time.
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
I did this just the other night. I had my MacBook hooked up over ethernet to my desktop as I copied files back and forth. At the same time, i used the wireless on my laptop to surf the web and send an email.
If both connections lead to the same router however, OS X defaults to the fastest connection available. So, if I have my laptop wired and wireless-ed into my router, it will use the wired connection. There is then a brief hiccup while it switches connections if I unplug the wired.
aphex
Moderator
Jul 19, 2001
38,572
I think my confusion stems from your wording, the Airport Express is a router. The Airport Card is what is in your Mac.
So you want to connect to two networks simultaneously, via your Airport Card & your Ethernet connection?
TheStu
Moderator
Sep 15, 2004
12,089
45
Originally posted by: ChAoTiCpInOy
How do you do it though? What if its two different routers?
It is generally easiest to have the wireless connected first, then you connect the wired. So you connect to Router A wirelessly, then plug into Router B.
ChAoTiCpInOy
6,442
I want to connect using wireless when I am away from the router, and wired when I am closer, without any lag or delay.
TheStu
Moderator
Sep 15, 2004
12,089
45
It will do it automatically. If you unplug the ethernet the wireless (if left on) will become your new internet connection. It should not causing any problems with transfers or downloads. The same is true in the inverse, with one exception, any transfers that you were doing over wireless will continue on wireless.
