Hello Everyone,
Yet again I have run into another, what seems to be complex problem.
Now even with something as simple as setting up a hard drive for data storage, you need a masters degree in computer science.
I am currently using Windows XP Pro and I have just purchased a WD Caviar Green WD10EZRX 1TB hard drive which is one of about 72 models that they have of their Caviar Green product (Don't even get me started how much time and research had to go into finding which one has problems or will have problems, etc.).
I will be using this hard drive internally and for data storage only.
I have heard that Windows XP is not compatible with the advanced format.
Okay, I have a couple of questions on how to prepare this drive....
1.) Is the problem with Windows XP that it just cannot be installed on an advanced format hard drive, or is it just how Windows XP saves files in general to all drives? Meaning if my drive is to only be used for data storage (no OS installed on it), will it work with Windows XP?
(In doing research I believe that it will be affected, but I just want to verify) I guess I am just hoping that I don't have to spend more time learning about how to align the drive and set the jumpers to a certain setting, etc. as I have read about.
If anyone has any simple info to share about how to do this, feel free to share it.
2.) I have also read that if you are using an IDE setting in your BIOS that you should install AHCI drivers and switch it back to AHCI. If anyone has any info on this to share, let me know.
Next question is more of a WD Caviar Green specific question
3.) In my research of Caviar Green drives it appears that older versions have problems due to an 8 second power down ......which I unfortunately suffer from too in the bedroom
but anyways, much like a firmware Viagra, WD came out with WDIDLE3.exe that allows you to extend its powered on performance
The newer drives are said to have been fixed, but I have read that they still have a power down setting of 8 seconds, how is it that these aren't affected by problems?
I have read that others still use the WDIDLE3 update on newer drives like the WD10EZRX, WD20EZRX, WD30EZRX regardless, to extend the 8 seconds to 5 minutes.
I was wondering if anyone has any knowledge or experience with this?
I am hoping that someone out there can take a little time to help me and share some knowledge. If not my only other solution is to dive back into my research, get even more frustrated, throw up, and then return the hard drive.
Thank You In Advanced For Any Help
