Hey,
can you help me out a bit?
The manual says this:
Using the Access Point Mode
Note: This advanced feature should be employed by advanced users only. The
Router can be configured to work as a wireless network access point. Using this
mode will defeat the NAT IP sharing feature and DHCP server. In AP mode, the
Router will need to be configured with an IP address that is in the same subnet
as the rest of the network that you will bridge to. The default IP address is
192.168.2.254 and subnet mask is 255.255.255.0. These can be customized for
your need.
1. Enable the AP mode my selecting ?Enable? in the ?Use as Access Point only?
page. When you select this option, you will be able to change the IP
settings.
2. Set your IP settings to match your network. Click ?Apply Changes?.
3. Connect a cable from the WAN port on the Router to your existing network.
The Router is now acting as an Access Point. To access the Router advanced
user interface again, type the IP address you specified into your browser?s
navigation bar. You can set the encryption settings, MAC address filtering,
SSID and channel normally.
It's a Belkin wireless router. Unfortunately, the problem I have is...... it says you need to connect the router to the other network USING A CABLE. So this basically means that I can't connect to it wirelessly?
-TPG
