Using a TV as a monitor & vice versa
Thetech
571
What would the pros and cons be for using a nice LCD TV as a computer monitor or using
an LCD computer monitor for a TV? I've thought about doing this for a while but I am
not sure of the cons though.
Thanks
Billb2
3,035
70
86
TV monitors usually have lower resolution that computer monitors.
Resolution means how many dots there are across the screen from side to side, and from top to bottom (as in 1280 x 1024).
Go sit 18" away from the TV you plan to use as a monitor and see if if it looks sharp at that disance.
And be aware that you have asked a very complex question that is difficult to answer completely in a few words, other than to say "that depends."
SSChevy2001
774
Many people on this forum are using HDTV as computer monitors just fine. I paid $550 for my Westhinghouse 37" a couple years ago, and IMO it was a great purchase. Right away you'll get the enjoyment of gaming and watch movies on a nice big screen. Also it's nice to use the PIP to watch a show plus game at the same time.
The big limit currently is resolution and aspect ratio. ( 1080P - 16/9 ). Also you just need to find a proper size to distance ratio. Don't go less than 1080P and you should be fine.
My next PC monitor will again be a HDTV.
Infrnl
1,175
I us a HDTV for monitor as well and has better resolution and pic quality than my 20"
As long as its a 1080P there will be no issues; plus you have many inputs for other use.
Also for a pc monitor comparable in size to say a 32" the HDTV will be much much cheaper if you look for the deals.
I have a Samsung LN32A550 1080P which sold for $1200 locally. I paid $650. show me where you can get a good 30" monitor for close to that and have the same picture quality.
Also keep in mind that on a 30" monitor will have to upscale to get higher res than native and will not be any better than 1080P. I dont know the specifics, but I read something on it yesterday. If I come across it again I will post it here.
For the money I think there is more value in a HDTV
EDIT: wanted to add that for larger monitors; HDTV would be a better deal IMO. I dont think you can get 1080P untill youu get a 32" possibly 26", but a 26" may cost a little more than a pc monito but will have more options. anything below this; I think a pc montor will provide you with higher res for the price
Thetech
571
Thanks for the info guys. Just to help clarify things (I should have stated this from the get go) I understand tech speak.
I know pixels and resoloution etc. (Thank you for taking the time to explain though Billb2). I like the Idea of just having an LCD HDTV.
But I just wasn't sure how they compare quality wise to a monitor. At first I'll be using it for my Wii and then eventually for a lower midrange gaming pc I
plan on building.
AstroManLuca
15,628
Another possible problem is that a lot of TVs use an overscan image - that is, the image spills off of either side. You can usually configure it to look right though.
And if you're using it as a monitor, I'd definitely say you'll want a 1080p LCD. LCDs have the sharpest, most defined pixels, and 1080p is way more useful than 720p for use as a monitor.
I have a 32" 720p LCD and I'm happy with it and I even use it as a monitor sometimes, but it's not good enough to use full time.
Thetech
571
How much would 120Hz really matter on an LCD TV?
*Edit* Made a new post in the correct area (Home theater) regarding THIS specific question *Edit*
