Using a treadmill without any sneakers on...
Mar 15, 2003
12,668
103
OK, sounds like an insane question, I know.. Do I really have to put my stinky sneakers on when doing some walking (not running) on my treadmill?
OutHouse
36,410
616
sounds crazy but the idea of keeping your toes attached to your foot would seem to answer that question for you.
blackdogdeek
14,453
10
the treadmill would be a more forgiving surface than concrete definitely. however, you'll still do much more damage to your feet and legs than you would if you wore sneakers.
Amused
57,547
20,261
Do you like the skin on the bottom of your feet? Treadmills have "non-slip" belts.
PanzerIV
6,875
I think at least for the sake of comfort I would leave shoes on. It would seem better for your feet too.
vi edit
62,484
8,345
Unless your feet are super calloused over, then you are going to do a number on them. The belts, like Amused said, are quite unforgiving.
Viper GTS
38,107
433
If you lose a few digits will you quit making movies?
Answer quickly, my advice depends upon it.
Viper GTS
Raj
951
probably bad for your feet if you don't.
particularly your knees. I used to run track.
good footwear is important when running.
you also should have proper arch support.
ohtwell
14,516
9
I can't imagine what would happen if your feet started to sweat. That would be nasty and dangerous.
: ) Amanda
pyonir
40,856
321
Viper GTS
lmao
minendo
35,560
22
Viper GTS
:beer:
