Actually, standard definition TVs can't do better than 640x480. Most video cards with s-video out will let you select higher resolutions, but in effect, all that really does is make everything smaller, and more blurry. It's downrezzed to what the TV can display. The higher resolutions are useful if you are using a computer monitor and the TV at the same time, and want the higher resolution on the monitor even if it means making what's on the TV harder to read. I have an HTPC that is hooked up to a 46" HDTV, and even with the resolution that TV is capable of (over DVI... s-video can only transmit SD signals), I still only run it at 540x960, as that's the highest my set is capable of running in progressive mode. I CAN output @ 1920x1080, but that mode isn't very useful for computer work. The combination of the interlacing and the fact that everything is really too small to get sufficient detail out of make it too hard to read. The higher resolution is really only useful for HD video.
