Using a switch with 2 subnets
MJoshi
Is it possible to use a switch with 2 subnets?
The application is VoIP and data to run on 2 different subnets which have separate dedicated Broadband lines. The two Broadband routers will be connected to the same switch.
I would like to route the VoIP traffic to the Broadband router and data traffic to the data router using a switch?
The switch I intend to use is the Netgear Smart FS728TP as it has PoE on all 24 ports and VoIP prioritisation.
Thanks.
Yes, it's possible. Since you have a managed switch that supports VLANs, I suggest created a VLAN for VoIP and data, assigning switch ports to the VLAN as needed, and then setting up your QoS settings for each VLAN.
If you have a managed switch, then you are able to create and direct traffic onto two different subnets. Otherwise you would have to use a router to manage the traffic correctly.
A managed switch will allow you to isolate VLANs. However a "layer 3 switch" otherwise known as a router on a switch is required to move data between both subnets. However it appears (from what I can tell) that you are using 2 different web routers with 2 different internet connections. So as long as each router is on a separate vlan that is reachable by each device it should work. Some switches even allow for a certain level of "auto config" to let devices choose which vlan they connect to. IE data > vlan 100 voice > vlan 200.
I spoke to Netgear tech-support and they have told me that with any Layer 2 switch, it is not possible to support 2 subnets on separate VLANs?
I was told that I would need a Layer 3 switch for this? However, I do not want to route traffic between the 2 subnets.
They said that it is only possible to group ports on a Layer 2 switch. Both VLANs must be on the same subnet?
Am I being given the correct information? I just want to have 2 subnets grouped separately and the Broadband routers will be performing DHCP to assign the IP addresses on each VLAN.
You need a managed layer 2 switch.
Example of a layer 2 switch with vlans (vlans are a layer 2 service)
http://www.cisco.com/en/US/prod/col...s6545/product_data_sheet0900aecd80322aeb.html
Specifically:
Virtual LANs (VLANs): Up to 32 VLANs (1000 range) and support for 802.1Q trunking using Cisco Smartports
Basically he was wrong. IP is a layer 3 technology. On a layer 2 switch you can create 2 vlans and run 2 IPX networks over them if you wanted.
