As long as you use decent quality splitters, it is no problem. My signal is split twice(one HQ grounded, one cheapish radio shack) before it gets to my cable modem, and I have no loss in dB.
Even with the best splitters I thought you lose 1/4 - 3/4 the signal. At least that's what Comcast said when they came out to our house and found a two and three way splitter.
Impedence is measured in ohms, right? I don't see any product sites that have that information. They only say mhz. I'm looking at a Radioshack one that's 5-2300mhz. Is that good enough?
you are correct clicknext. my splitter doens't specify the impedance but it does show the freq. range and the SNR. The 5-2300MHz splitter you found, does it list the SNR? That one's got a better range than mine, I might want to check it out.
Yep. I think that DSV 50 might be hinting at a 50dB SNR but I can't be certain... My splitter has only a 35dB SNR but it's definitely sufficient for my needs. It splits my cable modem line giving me an input to my Leadtek TV card.
Not only should you get a high quality splitter, you should also get good cables. If you still have issues, check for other splitters throughout the house. In my case, the tech installed a bad splitter.
<--- recently got Comcast, and went through all this. (I have a tv-tuner card hooked up, along with cable internet.)
