Using a second router as a wired/wireless access point
Johnbear007
4,570
I have a couple of netgear routers, an mr814 and then a similar wireless g version. Is it possible to set one up as a wireless access point in another room, not to use for wireless devices, but to use it's ethernet ports to connect other devices (ie ps2 etc) ?
Venomous
1,180
Yes, you will bypass this function by just connecting into the switch side. Dont use the WAN port.
