Using a rheobus on a high cfm fan
amcdonald
4,012
I have a delta afb0812sh that was bundled with my alhpa 8045...
I'm wondering how this fan will perform as a case fan controlled with a rheo bus...
Has anyone undervolted this fan? how does it sound at lower rpms?
What other high cfm fans are known to have a good db ratio at lower rpms?
Thanks
blade
1957 - 2008<br>Elite Moderator Emeritus<br>Troll H
When I see the name "delta", I run and go hide.
I have a ToCools fan that happens to be that exact same model # you have. Has the name ToCools but is made by delta. I use the Sunbeam rhoebus and it really quietens it down while still cooling well. At under 3k rpm, I can't hear it. It's the least noisy fan made by delta I've ever had.
amcdonald
4,012
Thanks, thats what I wanted to hear =)
I'll be using a sunbeam as well, so I'm glad to hear.
