We currently have all the hardware and software setup for the VoIP to work (it works on our internal LAN) but the problem I have is getting the phones to work in remote locations.
I know the most common practice is to use a VPN Endpoint (like a BEFSX41) to connect into a IPSec VPN but it looks like you have to have static IP's at both ends for IPSec to work properly and we can't get static IP's at the users houses (since they are using a home internet connection).
We are currently using a PPTP connection for the users to connect into the LAN from home and do work over RDP. What I am hoping can be done (I hope I can explain this good enough) is add a second NIC card into their home machines that the i2004 sets will use to connect through to the PPTP connection when they connect in to use RDP.
I have messed around with ICS on the VPN connection but I can't seem to get it to work, I think I am missing something (like the right IP address settings). Does anyone have any experience with this or have an idea on how I can make these i2004 sets work without a IPSec connection?
Thanks,
Frank
Thanks,
Frank
