Using a HD5450 on a Dell P4 with a PCI Express x1 slot + 230W PSU
Coup27
2,140
My friend has an old Dell Dimension 3100 with a Pentium 4 CPU. He says he can't afford to replace his computer but would really like to get rid of the low res CRT he has and replace it with a modern 1080p flat screen. I did try connecting it to a 1080p screen using the onboard video but either it didn't work or it would not support the full resolution (can't remember now).
I think the cheapest way of doing this is to buy a HD5450; however the board only has a PCI Express x1 slot and the PSU is only 230W. AMD recommends a 400W or greater PSU but I know from experience that I do not need 400W's.
Does anybody know whether the card will work OK on a 230W PSU and if the card can drive a 1080p display using DVI on only a x1 slot?
Thanks.
Phynaz
10,140
819
Onboard video should work fine. It's specs say it can run 2048x1536 at 85 Hz.
The HD5450 requires an x16 slot.
NTMBK
10,525
6,050
You can get something like this: http://www.amazon.co.uk/StarTech-com-Express-Profile-Extension-Adapter/dp/B0039XPS5W It turns a full height x1 slot into a half height x16 slot. (ONLY MECHANICALLY. Electrically, it's still an x1 slot, it just fits a physical x16 card.) No guarantees on performance...
Alternatively, you can get some graphics cards to fit into a PCI slot still. Something like this: http://www.ebuyer.com/500953-zotac-gt-610-pci-1gb-graphics-card-zt-60606-10l PCI has similar bandwidth to a PCIe Gen 1 x1 slot, so it's a toss up which will perform better.
Coup27
2,140
I'm afraid it did not work. I think he would also like to use DVI over VGA.
It was my understanding that a x16 card is backward compatible with x1 x4 etc only with reduced functionality? Or am I mixing that up with x1 cards in x16 slots?
He is already using both PCI slots for existing cards.
