Hi all -
I'm actually quite confused over which one to do. I had an experience where I had very odd lighting (a very low low light room where I needed to bounce flash off...but all the walls and ceilings were yellow) and am having trouble correcting it.
so I got interested in using a card for a custom white balance. apparantly white cards are trickier to use as overexposure can easily happen, so the proper choice is a gray card which yields more accurate results. After reading and googling so much I've noticed there are actually MANY different kinds...and I'm not sure which one to use (heck, there are even color checkers!).
18% is the most common one that appears- but I read that this is actually a mistake and that it is for printing....and that 12% should be used. But then numbers like 13% appear randomly.
I'm sure that in reality 12 to 13% probably makes absolutely no perceptible difference. 18% maybe make a minor difference, but doesn't matter in most cases.
But i'm still interested in what is technically the "proper" card to take a w/b reading off of.
