How do you get a fax machine to dial out on a multi-line system? The machine I set up will send a fax on a single line system without a problem.
However, when I plug the fax into a jack that had a multi-line phone attached to it, it doesn't get a dial tone. The multi-line phone is attached to the fax, and the fax is attached to the phone jack. When you pick up the phone and choose a line you get a dial tone. Should there be a button to press on the fax before sending to choose a line? Can a fax work on this kind of line? Thanks.
