Using a 266mhz FSB CPU on a 200mhz Mobo- will this work?
ripthesystem
571
Basically what the title says:
I have a Soyo Mobo and was wondering if I could put a TB 1.40/266 or a TB 1.33/266 in and have it work without problems since the motherboard says '200 MHz System Interface Speed'.
thanks
ripthesystem
xfactordomine
139
It should work, but your rig will be limited to a 200Mhz FSB. Pretty much same scenario as using PC133 RAM in PC100 slots.
-X
Markfw
May 16, 2002
27,341
16,169
It will probably work, but not at the regular speed. Inless you can unlock it, it will run at 100*(whatever the old mutiplier) In other words, a 1.33 gig processor would run at 1.0 ghz (100*10)
ripthesystem
571
Ok.
I think I'm starting to get it. I'm a complete multiplier n00b. So what you're saying is that a 1.33/266 will run at 1.0/200 on this mobo? does that mean that the 1.4/266 will run at 1.0/200 as well? I'm confusing myself as I type.. hmmm.
At that rate then a 1.2/200 CPU will run at stock and therefore be faster than the faster CPU? head getting stuffy.. need FAQ ;)
ripthesystem
Markfw
May 16, 2002
27,341
16,169
OK. A 1200c = 9x133, a 1333 = 10x133, a 1400=10.5x1333, SO
A 1200c in a 100 (200 double) bus system=9x100=900
A 1333c in a 100 (200 double) bus system=10x100=1000
A 1400c in a 100 (200 double) bus system=10.5x100=1050
Clear as mud ? If you can "unlock" the cpu, I think the multiplier goes up to 12.5 on most systems which would be 1250 best.
MadRat
11,999
308
They do make a Duron-Morgan at 1.3GHz and a Thunderbird at 1.4GHz, both using the 100MHz/200fsb.
ripthesystem
571
woah! it's muddy in here;)
think I've gotten the general Idea. This doesn't affect the way the L2 cache is used in anyway does it?
Madrat- I know they make the 1.3-1.4/200 (Tbird and Duron) I was trying to skip the Duron because the cache seems smaller than the Tbird(am I right? if not what IS the difference?).. Which leaves the TBird but it seems to be more expensive than the 1.3-1.4/266.. which is what led me to my original question.
thx all.. I'm still learning but I'll get it eventually.
ripthesystem
MadRat
11,999
308
Duron-Morgan
.18-micron
SSE-enabled
64k L2 / 128k L1
hardware prefetch
100fsb
Thunderbird
.18-micron
no SSE unit
256k L2 / 128k L1
no hardware prefetch
100-133fsb
ripthesystem
571
Thanks for the side by side MadRat- hmmm. After reading this I've started looking at benchmark comparisons. Seems that the TBird definately has the upperhand- though not by a lot- esp in real world 2D desktop work. So is it safe to say that the Duron is like the Celeron where the TBird would be more comparible to a Pentium (x)? I guess it all comes down to the $$ spent huh? Would a Duron 'seem sluggish' as compared to a Tbird?
MadRat
11,999
308
I don't think the Durons seem sluggish unless its using SDRAM at 100MHz. I set my mother up running a Duron at 800MHz and PC133 at 133MHz. Her system is quiet and fast for her needs. The biggest load she puts on it is writing MP3s to audio CDs, hardly a load really. Her generic motherboard doesn't have a BIOS upgrade for the Duron-Morgan else I'd have her on that one. Wouldn't even think about the Tbird for her because the powersupply is only rated 150W.
