Originally posted by: Bar81
The difference between DDR400 and DDR333 on an A64 is 0-3% (that's right you read zero) I've done my own testing on this matter. I think DDR333 or 400 depends on the mobo implementation strangely. I know AMD recommends DDR333 with all four banks filled but people have run DDR400 in that scenario.
As to CAS latency, that also is largely irrelevant on an A64 platform; you won't ever notice a real world difference. In fact even on an Intel platform the only place you really saw a real world detectable gain was Quake III, and maybe some encoding apps???
Sorry, that's simply not accurate. Where you're pulling those numbers from I'd like to know?
Socket 939 Dual-Channel motherboards were found to exhibit a very wide performance difference between a Command Rate setting of 1T and a setting of 2T. The impact on memory bandwidth is dramatic between these 2 settings. In SiSoft Sandra 2004 standard buffered Memory Benchmarks, a 1T command rate showed a Sandra bandwidth of 6000 Mb/sec, while a 2T rate with the same 2 DIMMs in Dual-Channel mode was only 4800 Mb/sec. This is a huge difference in memory bandwidth and the Command Rate setting definitely impacts performance test results on Socket 939 motherboards. All AnandTech benchmarks were run at a Command Rate setting of 1T. This includes all benchmarks that were run in the CPU tests, as all benchmarks were rerun in the CPU tests as soon as we had verified the performance impact of Command Rate settings.
***********MAY 1 2005**************
Edit: Since we have not found anything around the net or at reviewers sites dispite thier 1T "massive" benefit claims our members have done some tests!!! Wooo woooo.. I am leaving out synthetics since we already know the crazy story they like to tell; Sandra a whopping 35%, everest a massive 25% etc etc etc. Screw that! We don't want to freighten people into running 1T But we rather give a realistic performance benefit they see moving from 2T to 1T all things being equal.
GuitarDaddy System: CPU - Winch@2548Mhz | Memory- 2-3-2-7 X @232Mhz
SuperPI 8m 1T- 6:03m
SuperPI 8m 2T- 6:09m
1T is 2.4% faster
Aguamark3 1T- 58156
Aguamark3 2T- 57985
1T is 0.3% faster
3dmark 03 1T- 6908
3dmark 03 2T- 6872
1T is 0.5% faster
HL2 1T- 97.5fps
HL2 2T- 95.5fps
1T is 2.2% faster
X2 the threat 1T- 87.4fps
X2 the threat 2T- 85.8fps
1T is 1.9% faster
Doom3 1T- 85.9fps
Doom3 2T- 84.3fps
1T is 1.9% faster
Not looking good for 1T supposed "have to have" (thanks GD)
Sir Avalon System: CPU - Sempy128KB@1800Mhz | Memory- 2-2-2-10 X @225Mhz
SuperPi 1M 1T- 49s
SuperPi 1M 2T- 50s
1T is 2.0% faster
HL2 (coast 05, 1024x768, 2xAA/4xAF) 1T- 83.5fps
HL2 (coast 05, 1024x768, 2xAA/4xAF) 2T- 81.0fps
1T is 3.0% faster
Doom 3 (1024x768, 2xAA/4xAF) 1T- 74.8fps
Doom 3 (1024x768, 2xAA/4xAF) 2T- 73.5fps
1T is 1.2% faster
Avalon's using a 128KB LVL2 chip which probably accounts for the "massive" 3% improvment in one game
Insomniak System: CPU - Winch@2400Mhz | Memory- 2.5-3-3-8 X @200Mhz
Battlefield Vietnam 1T- 106.5FPS
Battlefield Vietnam 2T- 102.1FPS
1T is 4.3% faster*
Source VST 1T- 164.7
Source VST 2T- 158.3
1T is 4% faster*
Super Pi 8M 1T- 6:49
Super Pi 8M 2T- 6:58
1T is 1.4% faster
3dMark03 1T- 9258
3dMark03 2T- 9187
1T is 0.8% faster
Far Cry 1T- 105.2
Far Cry 2T- 103.4
1T is 1.7% faster
Insomniak definity showed the most pronounced differences so far, had a couple games in the 4% range. As and average though he's still less than 2%.
blckgrffn System: CPU - 754NC@2600Mhz | Memory- 2-3-3-5 X @195Mhz
Doom3 1T- 103.1
Doom3 2T- 99.2
1T is 3.7% faster
3DMark2001SE 1T- 22543
3DMark2001SE 2T- 21970
1T is 2.6% faster
DUVIE (from anotherthread) System: CPU - Winch@2640Mhz | Memory- u/k timings X @275Mhz
No data Duvie does the math for us: 1T vs. 2T
cinebench 2003 = 0%
superpi 2mb = <3%
prime95 benc 2048K = >1%
Povray 3.5 chess2 = 0%
3dsmax7 rendering = 1%
winrar (file compression) = 7%
the TMPGenc was 1%
"I dont see it ppl...tell me apps this will show up.... "
Came across a Corsair Whitepaper that has some interesting info. They used Doom3 time demo on 3500+ 939 setup. Summary of conclusions pertaining to the topic at hand:
1) 2-2-2-5 1T vs. 2-2-2-5 2T, -3.29% performance loss in Doom3 timedemo, more so than any other timing change.
2) 2-2-2-5 1T vs. 3-3-3-8 2T, -17% in Sisuck Sandra, 90% attributable to CPC change.
Zebo, I had run a couple gaming benchmarks in my Sempron 2800+ 90nm thread, and found that dropping your memory command rate to 2T was the equivalent of a 400mhz drop in CPU speed at 10x7. At least I think it was about 400mhz. It's in my thread somewhere, but I remember it being definitely noticeable.
After reading Toms hardware article on memory timings I stand corrected. It[Cas 2] appears to gain about 6% over CAS 3.
Okay, so you quoted Sandra numbers several times. Big deal as it's not real world. And you posted some numbers by people whose testing acumen I can't vouch for to disprove my own numbers. Sorry, not nearly good enough. Besides the numbers don't even support your claims. I stand by my numbers. On the A64 1T and 2T settings will exhibit no real world noticeable difference due to the A64 architecture and it's onboard memory controller. Similarly the difference between DDR333 and DDR400 is 0-3%.
Just so it's clear to take the most extreme example, pit a CAS2 DDR400 system against a CAS3 DDR333 system and you'll see anywhere between a 1-5% difference. Outside of a framerate counter no person in the real world will be able to tell the difference.
Sorry, when your own numbers don't back up your claims your credibility goes right into the toilet. btw I never questioned the competence or integrity of the testers, I just simply stated that I don't know them; learn to read. Besides, they back ME up, so for the sake of argument they're the best testers in the worldYou really need to work on the whole supporting your argument thing, there are some kinks you need to work out.
Okay, so again let's take an even more extreme scenario and compare a DDR333 CAS3 2T system to one that has DDR400 CAS2 1T which is in itself a ridiculous scenario as we're leaving out the fact that in the real world a person running 2T is generally going to have more memory than one with 1T (and that will probably influence benchmarks) but for the sake of argument let's assume all else the same. Only then would you start approaching something that may, in certain programs, be a detectable difference *on the high end* of the 3-8% difference between the setups. But even then, remember you're looking at very specific apps. The majority of what's out there is handicapped by other factors given the extremely efficient nature of the A64 architecture and its onboard memory controller.
Originally posted by: mwmorph
seriously, 8% difference is somewhat noticible Rodz, it will actually be like 3-5 fps in most games, also 2gb is not need for xp or games. 1gb is entirely for all games/xp. unless you need photoshop or video editing. if you od, by all means go for it. 2gb at 2t is still going to be faster than 1gb a 1t for all apps, just that you dont get as much linear increase as if using 2x1gb sticks vs 2x 513mb sticks.
This may be a silly question, and outside of this discussion, but what about:
2 GB from sticks of 1024MB at CAS 2-3-2-5-T1 vs. 1 GB from 2x512MB sticks at CAS 2-2-2-5-T1
Thanks!
