Using 3 to 4 pin adapter on kt7raid, help!
MortaniuS
654
I try to use a 3 to 4 pin adapter on my kt7raid for my delta and all i get is beeps (guessing its a thing to warn that ur cpu fan isnt werking) any ideas how to disable this protection?
jd in IL
88
Yes, plug the Delta into Fan header 1. It won't kill the MB, Abit allows for .5A or 6 watts, enough to handle the mighty Delta 38.
