P-Pros also make fairly good low-end/household file server machines, if your mobo supports more than one CPU go out and find a good matched pair and watch it take on almost any non gaming task with ease.
You could aslo try to find the P-II 333 overdrive chip for it.. and extend its life a bit farther.
