I tried using Drive Image 2002 and it wouldn't copy my drive. Error 626 if you're interested. I borrowed a copy of Norton Ghost to do this job and now i have problems.
The Drive copied fine, no hitches or errors.
I unplugged the power from the old drive, and reworked the IDE cable so that the new drive was the only one on the chain. Booted. Nothing worked, it got to the windows screen that comes up when it's loading your profile and froze.
Plugged everything back in like it was, booted from the old drive, perfect.
left everything plugged in like that, used my BIOS to boot from the new drive. Worked perfect.
Here's the problem iv'e discovered.
The Old drive was C:\. the New drive is J:\. WHen i boot from J:\ it's still looking for files on C:\. If C:\ is present then i'm kosher. If C:\ is gone then i'm screwed. I have tried changing J:\ to C:\ but it wont' let me. I managed to get C:\ to be like K:\ or something, and now it won't boot from the new drive at all.
Is there a quick way to change that damned drive letter with a boot disk or something without formatting the drive?! There is a way i know, i've used it before, but i can't remember how to do it now 🙁
