Use new onboard sound or older Sound Blaster card
n1ascar
16
I need some input on which sound card to go with. Just built a new rig and used the ABIT AV8 3rd EYE motherboard. It has intergrated sound card:
from the manual
onboard 6-ChannelAC 97 CODEC
Professional digital audio interface supports optical S/PDIF Input/Output
using REALTEK software.
I also have left over from my old rig a older:
Sound Blaster Live x-Gamer 5.1 sound card.
My questions is which would you go with
The "newer" intergrated sound
or
The "older" PCI card
I am using "Cambridge Soundworks Four Point Surrond FPS 1800" speaker set. (about 4 years old)
Rest of the rig:
MB - Abit av8 - 3rd eye
Case - Antec SLK3000b
Power - FSP Blue Storm 400W
Chip- AMD Athlon 64 3000+ 1.8 GHz (939) 90 nm
Video- BFG GeForce 6800 OC
DVD+/-RW 16x|NEC ND-3520A
Soyo BAYONE EXTREME 9/1
Thanks
Kris
duragezic
11,234
4
Good question. I'd like to know this as well since I have onboard AC97 sound but I do have a Soundblaster Live Value somewhere still I think..
gsparesa
72
Why don't you go with the onboard sound first. If it doesn't fit your needs (gamer or audiophile), then try another sound solution. I bet you'll settle for the onboard solution. (easy, clean and sounds good enough for most needs)
Anyone started a poll about using onboard VS plug-ins for their sound choice, recently?
mwmorph
8,877
onboard uses cpu to decode audio. my realtek 97 or something also is influenced hy hdd activity interference(annoying buzzing sound audible thorugh heaphones when hdd speeds up). use a seperate card. free up some cpu cycles and you'll always(almost always anyway) get better sound quality.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
I'd run the card rather than integrated.
You can try out both and see what you like better.
duragezic
11,234
4
Ahah! I've always wondered wtf that annoying buzz was, didn't realize it came with hdd action. Looks like I'll be giving the Live! a try when I find it.
Zepper
18,998
I would also try the on-board sound first to see if it works OK for you. You can always disable the on-board sound an uninstall the driver if it doesn't. I really hate the way the SoundBlaster drivers stomp all over everything like an 800 pound gorilla and leave a pile o' crap in your Registry when you try to get rid of them - damned arrogant if you ask me. Who does Creative think they are anyway, Micro$oft???
.bh.
airfoil
1,643
While I agree in principle with Zepper, my preference goes to the PCI solution - old or not, the SB Live 5.1 is the better solution.
My recommendation though is to go with your ears to help you decide between both, and look at CPU utilization too.
Kremerica
632
do these responses of going with a pci card also work in my case ?
I just bought the asus P5GD2 Premium with hd audio onboard. .
OR
I have a crappy FAR maddog sound card....
the sound quality would probably be better with the onboard but would the pci card give me better gaming performance?
Cares
868
Hmmm ... I'm debating between using an Audigy Platinum or the DFI Lanparty NF4 Ultra-D onboard sound. Currently using onboard and no problems yet.
duragezic
11,234
4
Now I'm not sure if an Audigy is the greatest, but it seems like clearly the winner here... The sound quality would probably be as good or better, and performance should be better with the Audigy.
duragezic
11,234
4
OR
I wouldn't go with that shoddy of a sound card to gain a couple fps! :)
SNM
180
According to reviews, the DFI's got pretty good onboard: It's well-insulated because of the riser, and it's got some extra chip or something to take a big load off the CPU:
http://www.anandtech.com/mb/showdoc.aspx?i=2358&p=19
Basically, the DFI is always within ~2% CPU utilization of a built-in SBLive! (3D is 5.51% to 7.08%), as compared to 30% CPU usage on regular integrated audio with 3D audio. :D
