Use an old sound card or use onboard sound?
foolfromhell
277
I have a Creative SB Audigy LS from my old computer (2004)
I have ordered a eVGA 680i mobo w/ e6600 and a 8800GTX.
Should I use the Creative SB Audigy LS or use onboard sound on the 680i?
corkyg
Elite Member | Peripherals
27,370
240
A practical approach would be to try onboard - listen, and then try the the SB card and let your ears be the judge.
Seekermeister
1,971
Trial and error would be the surest way, but my guess is that the sound card would be better than the onboard sound.
corkyg
27,370
240
Originally posted by: oynaz
The Audigy would almost certainly be better.
Not if both the Audigy and the on-board exceeded the aural capability of the speakers, etc. If you installed top quality speakers, perhaps you would hear a difference.
NeoHC421
248
I thought that some dedicated sound cards free up your CPU in some games and lead to increased FPS...
That's what I heard, but maybe it doesn't apply to this particular sound card...
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
How exactly is the onboard sound lacking? Just wondering, because I was fully intending upon using onboard sound for my next build.
pkme2
3,896
I do video editing.
I use SB Audigy 2 and would never ever rely on any on-board audio for my recording sessions.
Playing back audio narration is about all on-board is good for.
You will find a lot of Audigy Soundcards in the better-built systems.
IMO, Any soundcard is better.. Read the AT sound threads about on-board audio.
They should settle this question, for sure.
hurtstotalktoyou
2,055
9
Remember there's more than just output. Onboard audio has some of the worst A-D capabilities I've ever heard. A PCI sound card is *almost always* better than onboard audio, even if it's the dirt cheapest card you can find.
But, yes, you can do a quick check to be sure by connecting the line in and line out ports on each device, then running benchmarks. Free benches are available on Google.
