- May 11, 2008
- 21,609
- 1,291
- 126
As a bit of an amateur enthusiast, i read this article about positrons and electrons appearing inside thunder clouds, but these did not dissappear again creating bright flashes of gamma rays, at least not immediately. Inside thunderclouds enormous electrical fields exist. And i read in another article that when an electrical field is strong enough, virtual particles at the right spot can be forced to separate from each other because of their opposite electrical charge and continue to exist for a short time. The idea is that virtual particles come to existence in pairs and annihilate each other again, this all happening constantly but in a very short time. But a strong enough electrical field can force them away and keep them in existence , electrons aways from positrons. This idea has been proposed by physists since the 1930 i just found out. And had to think about the article with the thunderclouds with positrons emissions.
Can this really be happening that a zone, a kind of natural well can exist when given the right circumstances inside thunderclouds where positrons do not get a chance to meet electrons for an amount of time ? Seems to me that the electrical field inside the cloud discharges and that then the positrons hit electrons and the annihilation starts, the emission of gamma rays.
Millions of volts can be generated inside thunder clouds.
http://phys.org/news/2015-05-physicist-mysterious-anti-electron-clouds-thunderstorm.html
http://www.newscientist.com/article...make-virtual-particles-real.html#.VVuGgkYa-Uk
A terrifying few moments flying into the top of an active thunderstorm in a research aircraft has led to an unexpected discovery that could help explain the longstanding mystery of how lightning gets initiated inside a thunderstorm.
University of New Hampshire physicist Joseph Dwyer and lightning science colleagues from the University of California at Santa Cruz and Florida Tech describe the turbulent encounter and discovery in a paper to be published in the Journal of Plasma Physics.
In August 2009, Dwyer and colleagues were aboard a National Center for Atmospheric Research Gulfstream V when it inadvertently flew into the extremely violent thunderstorm—and, it turned out, through a large cloud of positrons, the antimatter opposite of electrons, that should not have been there.
To encounter a cloud of positrons without other associated physical phenomena such as energetic gamma-ray emissions was completely unexpected, thoroughly perplexing and contrary to currently understood physics.
"The fact that, apparently out of nowhere, the number of positrons around us suddenly increased by more than a factor of 10 and formed a cloud around the aircraft is very hard to understand. We really have no good explanation for it," says Dwyer, a lightning expert and the UNH Peter T. Paul Chair in Space Sciences at the Institute for the Study of Earth, Oceans, and Space.
It is known that thunderstorms can sometimes make flashes of energetic gamma rays, which may produce pairs of electrons and positrons when they interact with air. But the appearance of positrons should then coincide with a large increase in the number of gamma rays.
"We should have seen bright gamma-ray emissions along with the positrons," Dwyer says. "But in our observations, we first saw a positron cloud, then another positron cloud about seven kilometers away and then we saw a bright gamma-ray glow afterwards. So it's all not making a whole lot of sense."
Adds coauthor David Smith of the UC Santa Cruz, "We expected the thunderstorm to make some forms of radiation but not this. We don't even know whether it's something nature can do on its own or only happens when you toss an airplane into the mix."
The physical world is filled with normal matter and antimatter. For every normal particle there's an antiparticle, such as an electron and its associated anti-particle, called the positron, which, when brought together, annihilate each other in a flash of gamma rays. It is, Dwyer points out, the very same process that is supposed to power Star Trek's Starship Enterprise.
Having boldly gone where few people should, Dwyer says the experience inside the belly of the beast provides further insight into the bizarre and largely unknown world of thunderstorms—an alien world of gamma rays, high-energy particles accelerated to nearly the speed of light and strange clouds of antimatter positrons.
One possible explanation for the sudden appearance of positrons is that the aircraft itself dramatically influenced the electrical environment of the thunderstorm but that, Dwyer says, would be very surprising. It's also possible the researchers were detecting a kind of exotic electrical discharge inside the thunderstorm that involves positrons.
"This is the idea of 'dark lightning,' which makes a lot of positrons," says Dwyer. "In detecting the positrons, it's possible we were seeing sort of the fingerprint of dark lightning. It's possible, but none of the explanations are totally satisfying."
Dark lightning is an exotic type of electrical discharge within thunderstorms and is an alternative to normal lightning. In dark lightning, high-energy particles are accelerated and produce positrons, which help discharge the electric field.
Says Dwyer, "We really don't understand how lightning gets started very well because we don't understand the electrical environment of thunderstorms. This positron phenomenon could be telling us something new about how thunderstorms charge up and make lightning, but our finding definitely complicates things because it doesn't fit into the picture that was developing."
Next-generation lasers will have the power to create matter by capturing ghostly particles that, according to quantum mechanics, permeate seemingly empty space.
The uncertainty principle of quantum mechanics implies that space can never be truly empty. Instead, random fluctuations give birth to a seething cauldron of particles, such as electrons, and their antimatter counterparts, called positrons.
These so-called "virtual particles" normally annihilate one another too quickly for us to notice them. But physicists predicted in the 1930s that a very strong electric field would transform virtual particles into real ones that we can observe. The field pushes them in opposite directions because they have opposite electric charges, separating them so that they cannot destroy one another.
Lasers are ideally suited to this task because their light boasts strong electric fields. In 1997, physicists at the Stanford Linear Accelerator Center (SLAC) in Menlo Park, California, used laser light to create a few electron-positron pairs. Now, new calculations suggest next-generation lasers will be able to create such pairs by the millions.
Chain reaction
In the SLAC experiment, only one electron-positron pair was created at a time. But with more powerful lasers, a chain reaction becomes probable.
The first pair is accelerated to high speed by the laser, causing them to emit light. This light, combined with that of the laser, spawns still more pairs, say Alexander Fedotov of the National Research Nuclear University in Moscow and colleagues in a study to appear in Physical Review Letters.
"A large number of particles will spill out of the vacuum," says John Kirk of the Max Planck Institute for Nuclear Physics in Heidelberg, Germany, who was not involved in the study.
In lasers that can concentrate about 1026 watts into a square centimetre, this runaway reaction should efficiently convert the laser's light into millions of electron-positron pairs, the team calculates.
Antimatter factory
That kind of intensity could be reached with a laser to be built by the Extreme Light Infrastructure project in Europe. The first version of the laser could be built by 2015, but it could take a few years after that to complete upgrades necessary to reach 1026 per square centimetre, says study co-author Georg Korn of the Max Planck Institute for Quantum Optics in Garching, Germany.
The ability to generate large numbers of positrons could be useful for particle colliders like the proposed International Linear Collider, which will smash electrons and positrons together, says Kirk McDonald of Princeton University in New Jersey.
But Pisin Chen of National Taiwan University in Taipei says the cost of the very powerful laser might make this method more expensive than the alternative. The standard way to create large numbers of positrons today is to fire a beam of high-energy electrons at a piece of metal to produce electron-positron pairs.
