Use 3.5V power LED connection on motherboard to control a 12V lighting accessory in a computer case?
chunsile
Er, maybe the describe of problem has a little lengthiness, forgive my poor express on text.
Background for the problem: I rebuilt my computer in a new case where the components fit a bit better. Everything is great, and I have no issues with it. However, because of the way they engineered the front panel LEDs, I don't have an LED indicator of computer sleep status. The power light is powered off their control board, which is powered from the PSU directly, so I don't have a sleep indicator.
Now, I could easily just get an LED and extension cable for a simple power LED installation, but I got to thinking that I'd like to try something a bit more elaborate. That is, instead of a single 3.5V LED, I want to use a 12V light source (such as a LED spotlight or cold cathode) and install that to have something that could indicate sleep/power status with a bit more style. I have a mesh grill on the front of my case, so I figure something that illuminates under the mesh would be cool looking and noticeable but also not be disruptive in a dark room (like if I'm sleeping). There's some hurdles to this, though. For one, I obviously can't power one of these straight from the motherboard connector. It doesn't provide enough voltage. For another, the PSU shuts off my case lighting when in sleep mode.
My proposed solution:
So, I'd like to make something to do what I want. I'm a programmer but I have tinkered with electronics kits as a child, so I'm familiar with some (very) basics, and have assembled circuits before (at least, from pre-written designs). It has been a while though and my efforts in designing my own analog circuitry are best not to be spoken of, so I hope I can do something simple, here.
What I figure I would have to do is build a simple circuit that uses the power output from the power LED connection on the motherboard to power a switch (of some sort) that would provide power to the 12V light source from a battery, which could be recharged from the PSU. I believe the 3.5V connection on the motherboard just provides straight power to a LED (if one is connected). But instead of a LED, I want to make it so that while the computer is powered on, it would close the circuit for the 12V light so it would illuminate, while simultaneously charging the battery. When in standby mode, it would light the LED (my motherboard causes it to blink) by drawing power from the now-charged battery.
Question:
I think that a simple relay switch would probably be adequate for controlling the 12V circuit, but they're noisy. Is there a solid-state alternative? Since I'm dealing with two power sources, I'm not sure if it's possible for me to isolate them easily in a single circuit without physical separation (as a relay switch would provide). As I said, I only tinkered with electronics kits as a child. I didn't take electrical engineering in college, as I got into computer programming instead. But if it is and is simple enough to implement, I'd prefer it.
Also, I'm sure that dealing with a rechargeable battery brings with it its own set of caveats and things to worry about (like worries of overcharging). Is there anything else that I'd have to take into account?
Thanks!
Feb 25, 2011
16,999
1,628
Solid state relays are a thing. They click on/off but are otherwise noiseless.
The battery/charging thing you can probably find a wiring diagram from an arduino or raspberry pi project site (there are a lot of semi-portable Pi projects that use AC charging as well as a battery.) Just "replace" the Pi, conceptually, with the 3v LED line from the motherboard (as the controller) and the 12v LED setup (as the consumer of power.)
serpretetsky
642
26
101
Do you know how your motherboard controls the power led? There should be two connections, + and -. Does it switch the negative or the positive terminal on/off to control the led?
Also, will your 12v supply come from the PSU that is powering your motherboard?
If yes and the mobo switches the LED with the positive terminal, then you can use a n-channel enhancement mosfet. The source would connect to ground, the gate would connect to the positive LED output from the motherboard, and the drain would connect to the negative terminal of your 12v lighting. The positive terminal of your 12v lighting would connect to +12v supply. You want to choose a mosfet that can supply a current (Id) high enough for your 12v lighting.
