I have a Canon D1250U2 USB2 scanner, & my motherboard (MSI KT3V, with built-in USB2 controller) does not recognise the presence of it.
The USB controller initially recognised the scanner correctly, that was before I installed the USB2 controller drivers. When I reached the final stages of installing the USB2 driver, a dialog box popped up, & it was the pc detected the connection of the scanner & asked me for the scanner's drivers. I didn't install the scanner's drivers then, instead I continued the installation of the USB2 controller driver & proceeded to reboot. After rebooting, the pc does not detect the presence of the Canon scanner, & the dialog box asking for the scanner's drivers never popped up again. I tried uninstalling & reinstalling the controller drivers, installing another Adaptec USB2 card, unplugging & repluging, everything, but to no avail. It is really frustrating as I cannot use the scanner now, the scanner app cannot communicate with the scanner. I would be grateful if anyone can help out here, as the scanner was operating normally before I swapped out the mobo (previous mobo was MSI KT3 Ultra, with an Adaptec USB2 card). I must also say that Canon's drivers have conflicts with Logitech's webcam software, which needed to be uninstalled before the Canon drivers can be installed sucessfully.
Apart from the scanner, all other USB peripherals are currently operating correctly & normally. I'm using WinXP Pro.
TIA
TIA
